Wiz Home Tunable White 60W E27 Smart Bulb
Quicklinx: H664WS00 Mfr#: 929002383502
Type: Light bulb
Compatible With: Alexa, Google Assistant
£7.91 ex VAT
£9.49 inc VAT
Bring human-centric lighting into your life with this smart WiZ LED A60 tunable white bulb. Apply different shades of warm to cool white to help you focus or relax. You can set schedule to turn lights on and off according to your daily or weekly routines, control with your smartphone or your voice and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
  • Gentle LEDs, easy on the eyes
    It's easy to see how harsh lighting can strain the eyes. Too bright, and you get the glare. Too soft and you experience flicker. Now you can gently light up your world with LEDs designed to go easy on the eyes, and create the perfect ambience for your home.
  • Replaces standard incandescent
    With its beautiful design and familiar shape, this energy-saving LED bulb is the perfect sustainable replacement for traditional incandescent bulbs.
  • Similar shape and size as incandescent capsules
    With its beautifully shaped design and familiar dimensions, this is a contemporary lighting, LED capsule.
  • 15,000-hour rated average life
    With a lifetime of up to 15,000 hours, you can reduce the hassle of frequently replacing your light bulbs, and enjoy a perfect lighting solution for over 15 years.
  • A simple LED for everyday use
    This everyday LED is the perfect bulb for your basic lighting needs. It provides the beautiful light and dependable performance you expect from LED at an affordable price.
  • Instant on - start simple with smart Wi-Fi LED
    It's easy to get started with smart lighting. Simply screw in your bulb, download the WiZ app and follow the steps. And you're ready to go!
  • Instant app control
    Adjust the lighting from anywhere using the easy-to-use app. No need to go from room to room to make sure all your lights are off. Control all lights wherever you are with the smartphone app.
WiZ Connected - LED light bulb - shape: A60 - E27 - 8 W - warm to cold white light - 2700-6500 K
Light Source Type
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Warm to cold white light
Colour Temperature
2700-6500 K
Luminous Power
806 lumens
AC 220 - 240 V
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8 kWh
Lamp Current
70 mA
Colour Temperature
2700-6500 K
Colour Rendering Index
90
Luminous Power
806 lumens
Lifetime
25000 hours
Switch Cycles
50000
Voice control, app-controlled
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
Warranty
2 years
60 mm
122 mm
65 g
Type: Light bulb
Brand: Wiz Home
