Bring human-centric lighting into your living and working environments with this smart WiZ LED GU10 bulb. Apply different shades of warm to cool white to help you focus or relax. You can set a schedule to turn lights on and off according to your daily or weekly routines, control with your smartphone or your voice and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
- WiZ Whites - LED spot light bulb - shape: PAR16 - GU10 - 4.9 W - warm white to daylight - 2700-6500 K
- Light Source Type
- Shape
- PAR16
- Socket Type
- GU10
- Wattage
- 4.9 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm white to daylight
- Colour Temperature
- 2700-6500 K
- Luminous Power
- 345 lumens
- Beam Angle
- 36 degree(s)
- Dimmable
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Platform
- Nest, SmartThings, ecobee, Somfy TaHoma, Ring
- Communications Technology
- Bluetooth Low Energy (LE), Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
Light Source
- Shape
- PAR16
- Socket Type
- GU10
- Wattage
- 4.9 W
- 50 W
- F
- Energy Consumption per 1000h
- 5 kWh
- Lamp Current
- 40 mA
- 2700-6500 K
- Colour Rendering Index
- 90
- Luminous Power
- 345 lumens
- Maximum Beam Candela Power
- 550 cd
- Beam Angle
- 36 degree(s)
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 50000
- Indoor usage, app-controlled, lighting schedules
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Compatible Services
- IFTTT
- Voice Controlled
- Indirect
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 58 mm
- 50 g
