Enjoy more convenience in everyday life with this smart WiZ LED A60 bulb. This bulb gives soft white light that dims to your desired brightness level via app or voice. You can set schedule to turn lights on and off according to your daily or weekly routines, and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
- WiZ - LED light bulb - shape: A60 - frosted finish - E27 - 8 W - warm white light - 2700 K
- Light Source Type
- LED light bulb
- Shape
- A60
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 8 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 806 lumens
- Dimmable
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Platform
- Nest, SmartThings, ecobee, Ring
- Communications Technology
- Bluetooth, Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
Light Source
- LED light bulb
- Shape
- A60
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 8 W
- 60 W
- F
- Energy Consumption per 1000h
- 8 kWh
- Lamp Current
- 70 mA
- Warm white light
- 2700 K
- Colour Rendering Index
- 90
- Colour Code
- 927
- Luminous Power
- 806 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Indoor usage, light scheduling, app-controlled
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Bluetooth, Wi-Fi
- Compatible Services
- IFTTT
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 122 mm
- 60 g
- Shipping Dimensions (WxDxH) / Weight
- 7 cm x 7 cm x 16 cm
