Wiz Home Dimmable White 50W GU10 Smart Bulb
Quicklinx: H66SWS00 Mfr#: 929002448102
Type: Light bulb
Compatible With: Alexa, Google Assistant, Siri
£6.55 ex VAT
£7.86 inc VAT
Enjoy more convenience in everyday life with this smart WiZ LED GU10 bulb. Ideal for accent, display and task lighting. This bulb gives soft white light that dims to your desired brightness level via app or voice. You can set a schedule to turn lights on and off according to your daily or weekly routines, and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
WiZ - LED spot light bulb - shape: PAR16 - GU10 - 4.9 W - warm white light - 2700 K
Light Source Type
LED spot light bulb
Shape
PAR16
Socket Type
GU10
Wattage
4.9 W
Wattage Equivalent
50 W
Energy Efficiency Class
F
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
345 lumens
Beam Angle
36 degree(s)
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
Nest, SmartThings, ecobee, Somfy TaHoma, Ring
Communications Technology
Bluetooth Low Energy (LE), Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Source
LED spot light bulb
Shape
PAR16
Socket Type
GU10
Wattage
4.9 W
Wattage Equivalent
50 W
F
Energy Consumption per 1000h
5 kWh
Lamp Current
40 mA
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
90
Luminous Power
345 lumens
Maximum Beam Candela Power
550 cd
Beam Angle
36 degree(s)
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Indoor usage, app-controlled, lighting schedules
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Compatible Services
IFTTT
Voice Controlled
Indirect
Warranty
2 years
Diameter
50 mm
Length
58 mm
50 g
Type: Light bulb
Compatible With: Siri
Brand: Wiz Home
