Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
One channel thermostat pack ideal for combi-boilers. Enables you to control heating via the Wiser Heat app
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
- Multi-zoning - build the perfect system by adding Radiator Thermostats as required
- Works with Amazon Alexa
- Eco Mode - combines weather compensation & optimum stop for maximum savings
- Simplicity - standard wallplate, wireless devices
- Remote Control - simple app with boost & away mode
- OpenTherm® technology
Kit contains:
- 1 x Room thermostat
- 1 x 1 channel Heat Hub®
- 1 x Thermostat stand
- 1 x Thermostat wall bracket
- 2 x AA batteries
- 1 x OpenTherm module
- 1 x Wallplate
- Drayton Wiser Thermostat Kit 1 - thermostat kit - Wi-Fi
- Product Type
- Thermostat kit
- Power Source
- Battery
- Package Content
- Thermostat, system hub, control interface module
- Connectivity
- Wireless - Wi-Fi
- Frequency Band
- 2.4 Ghz
- Display
- 2.4" - LCD
- 7.6 cm x 2.5 cm x 7.6 cm
- Product Type
- Thermostat kit
- Power Source
- Battery
- Package Content
- Connectivity Technology
- Wireless - Wi-Fi
- Max Range Indoors
- 30 m
- Frequency Band
- 2.4 Ghz
- Display
- 2.4" - LCD
- 1 channel
- Temperature Range
- 5 - 30 °C
- Measurement Accuracy
- ±0.5 °C
Thermostat
- Humidity sensor
- Form Factor
- AA type
- Battery Included
- Required Qty
- 2
- Technology
- Alkaline
- Included Accessories
- Stand, wall plate, wall mount bracket
- IP20
- 7.6 cm
- 2.5 cm
- 7.6 cm
- 0 °C
- 45 °C
- 25 - 90% (non-condensing)
