Wiser Multi-zone Kit 1 for Combi Boilers
Quicklinx: D4ZSWS00 Mfr#: WV714R9K0902
Type: Thermostat kit
Compatible With: Alexa
More than 50 In Stock
£191.66 ex VAT
£229.99 inc VAT
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
One channel thermostat system with two radiator theremostats to start zoning your system. Suitable for Combi boilers. Set schedules for the room thermostat and radiator thermostats via the Wiser Heat app. Add more radiator thermostats to create more independent zones.
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
  • Multi-zoning - build the perfect system by adding Radiator Thermostats as required
  • Works with Amazon Alexa
  • Eco Mode - combines weather compensation & optimum stop for maximum savings
  • Simplicity - standard wallplate, wireless devices
  • Remote Control - simple app with boost & away mode
  • OpenTherm® technology
Kit contains:
  • 1 x Room thermostat
  • 1 x 1 channel Heat Hub®
  • 2 x Radiator Thermostats
  • 1 x Thermostat stand
  • 1 x Thermostat wall bracket
  • 6 x AA batteries
  • 1 x OpenTherm module
  • 1 x Wallplate
  • 2 x M30x1.5mm ring nut
  • 2 x Drayton valve adapter
  • 2 x Danfoss RA valve adapter
Drayton Wiser Multi-zone Kit 1 - thermostat kit - Wi-Fi
Thermostat kit
Functions
Humidity measurement
Power Source
Package Content
Thermostat, 2 x radiator thermostats, system hub, control interface module, 2 x Drayton valve adapters, 2 x Danfoss RA valve adapters
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Display
2.4" - LCD
1-year limited warranty
7.6 cm x 2.5 cm x 7.6 cm
Thermostat kit
Functions
Power Source
Package Content
Wireless - Wi-Fi
Max Range Indoors
30 m
Frequency Band
2.4 Ghz
Display
2.4" - LCD
1 channel
AA type
Battery Included
Alkaline
Stand, wall plate, wall mount bracket
Warranty
RoHS, Directive 2006/66/EC, Directive 2011/65/EU, EN 300 328, Directive 2014/53/EU, EN 60730-1, EN 60730-2-7
7.6 cm
2.5 cm
7.6 cm
45 °C
Brand: Wiser
Stock Status: Clearance
