WD_BLACK C50 Storage Expansion Card for Xbox 1TB
Quicklinx: HNKFWS00 Mfr#: WDBMPH0010BNC-WCSN
Form Factor: Media Drive
Capacity: 1TB
Interface: Xbox Series X/S
11 In Stock
£133.33 ex VAT
£159.99 inc VAT
Standard delivery Delivered within 3-5 working days
Say hello to more for your Xbox. As game files get larger, the WD BLACK C50 Expansion Card for Xbox is the fast and easy way to give your Xbox Series X|S a big capacity boost and keep more titles installed. Just plug this officially licensed card directly into the console for similar performance as the Xbox internal storage.
  • Xbox performance
    The WD BLACK C50 Expansion Card for Xbox leverages the Xbox Velocity Architecture and delivers similar performance as your Xbox Series X|S internal storage for a seamless experience with all your favorite games.
  • Store more huge titles
    Games are getting bigger, eating up more storage. Capacity from 1TB let you keep more of those titles installed and ready to fire up at a moment's notice.
  • Easy to install
    This officially licensed Xbox expansion card is plug-and-play with your Xbox Series X|S, so you don't have to worry about compatibility or opening your console to install.
  • Design by WD BLACK
    The expansion card's slick, industrial aesthetics deliver the cool factor that WD BLACK is known for and fit in perfectly with your Xbox console.
  • Store more, play more on Xbox
    Non-expansion card solutions require you to transfer games back and forth to your console. The WD BLACK C50 Expansion Card for Xbox lets you get into the action faster so you can game when you want to.
  • Quick resume-compatible
    Suspend your current game, play a different game, then come back to the first game as if you never left. Only the Xbox console's internal SSD and expansion cards can support this time-saving feature.
WD Black C50 Expansion Card for XBOX - hard drive - 1 TB
Hard drive - external (portable)
1 TB
Xbox compatible
31.6 mm x 55.6 mm x 7.7 mm
25 g
5-year warranty
1 TB
Xbox compatible
31.6 mm
55.6 mm
7.7 mm
25 g
Software Included
Xbox Game Pass Ultimate (1 month)
Xbox One S system software, Xbox One X system software
Protective cover
Limited warranty - 5 years , Money back guarantee - 30 days
-5 °C
55 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Capacity: 1TB
Brand: WD
