WD Ultrastar Data102 1224TB SAS (102 x 12TB He12) 102 Bay Rack NAS
Quicklinx: DXJQWS00 Mfr#: 1ES0309
Type: Storage enclosure
Controller Type: None
£37,700.03 ex VAT
£45,240.03 inc VAT
The Ultrastar Data102 is a key element of next-generation disaggregated storage and software-defined storage (SDS) systems, delivering extreme density and the flexibility to balance performance with cost. Conventional dense disk shelves frequently suffer from performance degradation due to induced vibration from adjacent drives. Traditional platforms also have cooling challenges as the cooling air passes over successive rows of drives, losing effectiveness as it gets heated up along the airflow path.
  • Designed for high density and flexibility
    The Ultrastar Data102 is a key element of next-generation disaggregated storage and software-defined storage (SDS) systems, delivering high density and the flexibility to balance performance with cost. The Ultrastar Data102 provides up to 1.2PB of raw storage in a compact and efficient form factor. Western Digital HelioSeal drives ensure cool running, quiet operation and high reliability. A high performance data tier can be set up for demanding applications by using SSDs in up to 24 of the drive slots.
  • Building on 50+ years of storage design experience
    Conventional dense disk shelves frequently suffer from performance degradation due to induced vibration from adjacent drives. Traditional platforms also have cooling challenges as the cooling air passes over successive rows of drives, losing effectiveness as it gets heated up along the airflow path. Developing storage devices and platforms side-by-side, we address these challenges through vertical innovation, a set of technologies developed based on a holistic view of devices, platform, and their interactions. The first two of these patented technologies are IsoVibe and ArcticFlow. IsoVibe reduces vibration-induced performance degradation, while ArcticFlow overcomes the cooling issues by introducing cool air into the middle of the platform. Both these technologies contribute to long-term reliability, enabling our five-year limited warranty on the entire platform.
  • Designed for the enterprise and the cloud
    This new platform addresses the demanding storage needs of large enterprise customers, storage OEMs, cloud service providers and resellers/integrators that require dense, shared HDD or hybrid storage. The Ultrastar Data102 provides the flexibility to specify the HDD and SSD combinations to balance capacity, performance and cost.
  • IsoVibe patented vibration isolation technology
    Precise cuts in the baseboard provide a suspension for the drives in the chassis, isolating them from transmitted vibration. The result is that consistent performance is maintained, even when all the drives are working hard.
  • ArcticFlow patented thermal zone cooling technology
    By introducing cool air into the center of the chassis, drives operate at lower and more consistent temperatures than conventional systems. This results in lower fan speeds, reduced vibration, lower power consumption, quieter operation and ultimately higher reliability
WD Ultrastar Data102 SE-4U102-12F04 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Total Array Capacity
1224 TB
Max Supported Capacity
1224 TB
102 (installed) / 102 (max)
Supported Drives
SAS-3
Hard Drive
102 x 12 TB HDD SAS 12Gb/s - hot-swap - Instant Secure Erase (ISE), 512e Crypto
AC 230V - 50/60 Hz
Power Redundancy
44.7 cm x 104.7 cm x 17.5 cm
118.8 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Chassis
102
Supported Devices / Modules Qty
102
Supported Drives
SAS-3
Storage
1224 TB
1224 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
102 x 12 TB
Interface Type
SAS 12Gb/s
Expansion Bays
102 (total) / 0 (free) x hot-swap - 3.5"
6 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
SCSI Enclosure Services 3 (SES3)
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V - 50/60 Hz
Power Provided
1600 Watt
44.7 cm
104.7 cm
17.5 cm
118.8 kg
Limited warranty - 5 years
5 °C
35 °C
8 - 80% (non-condensing)
Brand: WD
Price Range Ex VAT: £1500+
