WD Ultrastar Data102 1020TB SAS (102 x 10TB He10) 102 Bay Rack NAS
Quicklinx: DXJPWS00 Mfr#: 1ES0297
The Ultrastar Data102 is a key element of next-generation disaggregated storage and software-defined storage (SDS) systems, delivering extreme density and the flexibility to balance performance with cost. Conventional dense disk shelves frequently suffer from performance degradation due to induced vibration from adjacent drives. Traditional platforms also have cooling challenges as the cooling air passes over successive rows of drives, losing effectiveness as it gets heated up along the airflow path.
  • Expansive storage capacity
    With a total array capacity of 1020 TB and supporting up to 1224 TB, the WD Ultrastar Data102 SE-4U102-10F04 offers a vast storage solution, making it ideal for data centers and enterprises requiring large-scale data storage.
  • Enhanced reliability
    Equipped with dual internal power supplies with a 1+1 redundancy scheme and a nominal voltage of AC 230 V, this storage enclosure ensures a continuous power supply and operational reliability.
  • Optimized for durability
    The hot-swap feature for its 102 installed 10 TB HDDs, along with SCSI Enclosure Services 3 (SES3), enhances the system's durability and ease of maintenance, ensuring minimal downtime.
  • High connectivity
    Featuring six 36 pin 4x Mini SAS HD (SFF-8644) interfaces that support SAS 12Gb/s, the WD Ultrastar Data102 provides high-speed connectivity and fast data transfer rates for efficient operations.
  • Environmental resilience
    Designed to operate within a wide range of temperatures from 5°C to 35°C and a humidity range of 8 - 80% (non-condensing), this storage enclosure is built to withstand various environmental conditions.
WD Ultrastar Data102 SE-4U102-10F04 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Total Array Capacity
1020 TB
Max Supported Capacity
1224 TB
102 (installed) / 102 (max)
Supported Drives
SAS-3
Hard Drive
102 x 10 TB HDD SAS 12Gb/s - hot-swap - Instant Secure Erase (ISE), 512e Crypto
AC 230V - 50/60 Hz
Power Redundancy
44.7 cm x 104.7 cm x 17.5 cm
118.8 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Chassis
102
Supported Devices / Modules Qty
102
Supported Drives
SAS-3
Storage
1020 TB
1224 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
102 x 10 TB
Interface Type
SAS 12Gb/s
Expansion Bays
102 (total) / 0 (free) x hot-swap - 3.5"
6 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V - 50/60 Hz
Power Provided
1600 Watt
44.7 cm
104.7 cm
17.5 cm
118.8 kg
Limited warranty - 5 years
5 °C
35 °C
