Tackle extreme workloads in high-intensity NAS environments with the fast-caching WD Red SN700 NVMe SSD. The drive's robust system responsiveness and exceptional I/O performance are perfect for multi-user, multitasking applications, letting you tame your SMB's toughest projects from virtualization to collaborative editing to intensive database storage with efficient caching - all while helping to lower your TCO.
Accelerate your NAS
The fast-caching power of the WD Red SN700 NVMe SSD delivers robust system responsiveness and exceptional I/O performance. -
Built to last
Tackle 24/7 NAS workload environments with reliability. -
Step up to NVMe
Tame your SMB's toughest projects - from virtualization to collaborative editing to intensive database storage with efficient caching - with storage designed to outperform while helping to lower your TCO. -
Perfect for SMBs
Even in smaller operations, multiple people working at the same time can tax a NAS device. NVMe caching easily handles random workloads in multi-user, multitasking applications to let small-to-medium businesses do more. -
Optimize your workflow
Purpose-built and tested to be compatible with many of today's most popular NAS systems for maximum flexibility to optimize your workflow.
- WD Red SN700 WDS250G1R0C - SSD - 250 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 250 GB
- Form Factor
- M.2 2280
- Interface
- 24x7 continuous operation
- 22 mm x 80 mm x 2.38 mm
- 7.5 g
- 5-year warranty
- Capacity
- 250 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 2.38 mm
- 7.5 g
Performance
- SSD Endurance
- 500 TB
- Internal Data Rate
- 3100 MBps (read) / 1600 MBps (write)
- Maximum 4KB Random Write
- 180000 IOPS
- Maximum 4KB Random Read
- 220000 IOPS
Reliability
- MTBF
- 1,750,000 hours
- 24x7 Operation
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 70 mW (low power active) , 3.5 mW (sleep)
- UL, TUV, VCCI, C-Tick, BSMI, FCC, KCC
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -55 °C
- Max Storage Temperature
- 85 °C
