Packed with power to handle the small- to medium-sized business NAS environments and increased workloads for SOHO customers, WD Red Plus is ideal for archiving and sharing, as well as RAID array rebuilding on systems using ZFS and other file systems. Built and tested for up to 8-bay NAS systems, these drives give you the flexibility, versatility, and confidence in storing and sharing your precious home and work files.
Tackle intensity with WD Red Plus
Packed with power to handle the small- to medium-sized business NAS environments and increased workloads for SOHO customers, WD Red Plus is ideal for archiving and sharing, as well as RAID array rebuilding on systems using ZFS and other file systems. Built and tested for up to 8-bay NAS systems, these drives give you the flexibility, versatility, and confidence in storing and sharing your precious home and work files. -
For small or medium businesses
Stream, backup, share, and organize your digital content with a NAS and WD Red Plus drives designed to effortlessly share content with the devices at your home or business. NASware 3.0 technology increases your drives' compatibility with your existing network and devices. For larger businesses with up to 24 bays, count on WD Red Plus drives to deliver exceptional performance. -
Exclusive NASware 3.0
Not just any drive will do. Get up to 14TB of capacity in your 8-bay NAS system and with Western Digital's exclusive NASware 3.0 technology, you can optimize each and every drive. Built into every WD Red Plus hard drive, NASware 3.0's advanced technology improves storage performance by increasing compatibility, integration, upgradeability, and reliability. -
Built for Optimum NAS compatibility
WD Red Plus drives with NASware technology takes the guesswork out of selecting a drive. Optimized for NAS systems, WD’s unique algorithm balances performance and reliability in NAS and RAID environments. Simply put, a WD Red Plus drive is one of the most compatible drives available for NAS enclosures. But don't take WD’s word for it. WD Red Plus drives are a reflection of extensive NAS partner technology engagement and compatibility-testing. -
WD Red Plus for Big Business
If you're looking for heavy duty performance for NAS, WD Red Plus drives deliver exceptional performance for the medium to large business customer with extreme demands. For NAS environments with 9 to 24 bays, WD Red Plus drives deliver uncompromising performance. -
3D Active Balance Plus
WD’s enhanced dual-plane balance control technology significantly improves the overall drive performance and reliability. Hard drives that are not properly balanced may cause excessive vibration and noise in a multi-drive system, reduce the hard drive life span, and degrade the performance over time. -
24x7 environment
Since your NAS system is always on, a reliable drive is essential. With an MTBF of up to 1 million hours, the WD Red Plus drive is engineered to tackle 24x7 environments. -
Desktop Drives vs. WD Red Plus
Do right by your NAS and choose the drive purpose-built for NAS with an array of features to help preserve your data and maintain optimum performance.
- WD Red Plus WD80EFZZ - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5640 rpm
- Native Command Queuing (NCQ), Advanced Format technology, 3D Active Balance Plus, 24x7 continuous operation, Conventional magnetic recording (CMR), NASware 3.0 technology
- 101.6 mm x 147 mm x 26.1 mm
- 750 g
- Localisation
- Worldwide
- 3-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 750 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 185 MBps
- Spindle Speed
- 5640 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.2 Watt (read) , 6.2 Watt (write) , 4.1 Watt (idle) , 0.4 Watt (sleep) , 0.4 Watt (standby)
- RoHS 2011/65/EU
- Localisation
- Worldwide
- Shipping Width
- 127 mm
- Shipping Depth
- 190.5 mm
- Shipping Height
- 63.5 mm
- Shipping Weight
- 0.85 kg
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Sound Emission
- 25 dBA
