WD Red Plus 6TB 5400 RPM Serial ATA III 3.5" 256MiB
Quicklinx: H2K4WS00 Mfr#: WD60EFPX
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 6TB
Spin Speed (rpm): 5400rpm
£216.30 ex VAT
£259.56 inc VAT
Packed with power to handle the small- to medium-sized business NAS environments and increased workloads for SOHO customers, WD Red Plus is ideal for archiving and sharing, as well as RAID array rebuilding on systems using ZFS and other file systems. Built and tested for up to 8-bay NAS systems, these drives give you the flexibility, versatility, and confidence in storing and sharing your precious home and work files.
  • For small or medium businesses
    Stream, backup, share, and organize your digital content with a NAS and WD Red Plus drives designed to effortlessly share content with the devices at your home or business. NASware technology increases your drives' compatibility with your existing network and devices. For larger businesses with up to 24 bays, count on WD Red Pro drives to deliver exceptional performance.
  • Exclusive NASware
    Not just any drive will do. Get a large capacity in your 8-bay NAS system and with Western Digital's exclusive NASware technology, you can optimize each and every drive. Built into every WD Red hard drive, NASware advanced technology improves storage performance by increasing compatibility, integration, upgradeability, and reliability.
  • WD Red Pro for big business
    If you're looking for heavy-duty performance for NAS, WD Red Pro NAS hard drives deliver exceptional performance for medium to large business customers with extreme demands. For NAS environments with 9 to 24 bays, WD Red Pro drives deliver uncompromising performance.
  • 3D active balance plus
    The enhanced dual-plane balance control technology significantly improves the overall drive performance and reliability. Hard drives that are not properly balanced may cause excessive vibration and noise in a multi-drive system, reduce the hard drive life span, and degrade the performance over time.
  • 24/7 environment
    Since your NAS system is always on, a reliable drive is essential. With an MTBF of up to 1 million hours, the WD Red Plus drive is engineered to tackle 24 x 7 environments.
WD Red Plus WD60EFPX - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
Native Command Queuing (NCQ), Advanced Format technology, 3D Active Balance Plus, 24x7 continuous operation, Conventional magnetic recording (CMR), NASware 3.0 technology
101.6 mm x 147 mm x 26.1 mm
750 g
3-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.7 watt (read/write) , 3.1 watt (idle) , 0.3 watt (standby) , 0.3 watt (sleep)
ROHS Directive 2011/65/EU, ROHS Directive 2015/863/EU
Limited warranty - 3 years
65 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
23 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 6TB
Brand: WD
