WD Purple SC QD101 1TB MicroSDXC UHS-I
Quicklinx: H2KNWS00 Mfr#: WDD100T1P0C
Type: microSDXC
Capacity: 1TB
SD Speed Class: UHS-I U1 / Class10
Hurry, only 2 left in stock!
£171.72 ex VAT
£206.06 inc VAT
Western Digital's WD Purple SC QD101 microSD card is designed specifically for the mainstream security camera market. Using advanced 96-layer 3D NAND technology, the card delivers a cost-effective combination of ultra-endurance and high performance, and its support for card health monitor functionality allows for pre-emptive storage management. With the fast-growing market of security cameras, and growing adoption of 4K video, this card offers the right combination of longevity and capacity to handle the 24/7 continuous recording workload.
  • Designed for surveillance
    WD is a market-leading brand which gives you assurance that this card is designed with the right robustness, performance and features for always-on security video cameras and edge devices.
  • Ultra-endurance
    WD Purple SC microSD cards are designed for continuous 24/7 recording should cameras lose connection with the NVR, providing additional confidence in your security video solution.
  • Smart storage maintenance
    Card Health Monitoring. In compatible cameras, card health monitoring capability allows you to get notified when it's time to service your WD Purple microSD card, so you can perform preemptive storage management.
  • Robust storage, indoors or outdoors
    Supports -25°C to 85°C temperature range; humidity resistant. Have peace of mind that this card is designed for continuous operation in extreme weather conditions and in a variety of climates.
  • Continuous capture, hours or days
    Capacities up to 1TB1. WD Purple microSD cards are built with advanced 96-layer 3D NAND technology, ensuring high performance, reliability, and endurance. Western Digital offers a wide range of capacities for different cameras, resolution, and recording implementations; use for both motion-triggered and continuous recording.
WD Purple WDD100T1P0C - flash memory card - 1 TB - microSDXC
Flash memory card
microSDXC
Storage Capacity
1 TB
Speed Rating
UHS-I U1 / Class10
Enclosure Colour
Purple
3-year warranty
Flash memory card
Storage Capacity
1 TB
Enclosure Colour
Purple
Speed Class
UHS-I U1 / Class10
microSDXC
Limited warranty - 3 years
14.99 mm
10.92 mm
-25 °C
85 °C
Type: microSDXC
Capacity: 1TB
Brand: WD
