WD Purple Pro 18TB 7200 RPM Serial ATA III 3.5" 512MB
Quicklinx: H2KCWS00 Mfr#: WD181PURP
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 18TB
Spin Speed (rpm): 7200rpm
£355.16 ex VAT
£426.19 inc VAT
WD Purple Pro drives are designed for advanced AI-enabled recorders, video analytics servers and deep learning solutions requiring additional capacity, performance and workload capability.
WD Purple Pro WD181PURP - hard drive - 18 TB - SATA 6Gb/s
Hard drive - internal
18 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
7200 rpm
Advanced Format technology, 24x7 continuous operation, Conventional magnetic recording (CMR), AllFrame AI, support up to 64 cameras, tarnish-resistant
101.6 mm x 147 mm x 26.1 mm
690 g
5-year warranty
18 TB
3.5"
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
272 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.3 Watt (read/write) , 5.9 Watt (idle) , 0.9 Watt (standby) , 0.9 Watt (sleep)
RoHS 2011/65/EU
Limited warranty - 5 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
50 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5
Type: Hard drive
Capacity: 18TB
Brand: WD
