WD Purple Pro drives are designed for new generations of high-end AI-enabled recorders, video analytics appliances, deep-learning servers and cloud solutions that can benefit from high-capacity storage with high performance and additional workload capability. WD Purple Pro drives feature AllFrame AI technology, which helps reduce frame loss, improve overall video playback, and not only enables recording of multiple streams per camera but also supports up to 32 AI streams per drive for deep learning analytics within the system. WD Purple Pro drives also feature enterprise-class performance, data integrity and drive reliability, especially in larger-scale systems and enclosures where operational vibration is present.
Empower your smart video solution
Western Digital is a worldwide leader in the hard drive industry. With WD Purple Pro smart video storage, you have a drive engineered for high performance, durability and workload capability for advanced always-on AI-enabled smart video recorders, appliances, and servers. Efficiently and effectively extract value and insights from streamed and stored video, and help deliver a smarter world with advanced WD Purple Pro smart video storage. -
Western Digital's exclusive AllFrame AI technology
All WD Purple Pro drives are equipped with AllFrame AI technology, which not only improves ATA streaming to help reduce frame loss and improve overall video playback, but supports up to 32 AI streams for Deep Learning analytics within the system. -
Multiple cameras, multiple streams
Modern recorders now support multiple video streams per camera. WD Purple Pro drives are optimized to support up to 64 HD single-stream cameras, and can also support the latest smart cameras that transmit multiple streams. With this flexibility, you can upgrade or scale your security or smart video solution in the future. -
Advanced workload capability for advanced systems
The combination of streaming optimizations and enhanced durability and reliability make WD Purple Pro smart video storage ideal for all analytics servers, whether processing video streamed directly from cameras or large-scale captured video data sets.
- WD Purple Pro WD121PURP - hard drive - 12 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Advanced Format technology, 24x7 continuous operation, Conventional magnetic recording (CMR), AllFrame AI, support up to 64 cameras, tarnish-resistant
- 101.6 mm x 147 mm x 26.1 mm
- 660 g
- 5-year warranty
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 660 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 245 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.6 Watt (read/write) ¦ 5.6 Watt (idle) ¦ 0.6 Watt (standby) ¦ 0.6 Watt (sleep)
- RoHS 2011/65/EU
- Limited warranty - 5 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
