WD Purple Pro 10TB 7200 RPM Serial ATA III 3.5" 256MB
Quicklinx: H2KGWS00 Mfr#: WD101PURP
Form Factor: 3.5
Type: Hard drive
Interface Type: [N/A]
Capacity: 10TB
Spin Speed (rpm): 7200rpm
47 In Stock
£266.30 ex VAT
£319.56 inc VAT
WD Purple Pro drives are designed for new generations of high-end AI-enabled recorders, video analytics appliances, deep-learning servers and cloud solutions that can benefit from high-capacity storage with high performance and additional workload capability. WD Purple Pro drives feature AllFrame AI technology, which helps reduce frame loss, improve overall video playback, and not only enables recording of multiple streams per camera but also supports up to 32 AI streams per drive for deep learning analytics within the system. WD Purple Pro drives also feature enterprise-class performance, data integrity and drive reliability, especially in larger-scale systems and enclosures where operational vibration is present.
  • Empower your smart video solution
    Western Digital is a worldwide leader in the hard drive industry. With WD Purple Pro smart video storage, you have a drive engineered for high performance, durability and workload capability for advanced always-on AI-enabled smart video recorders, appliances, and servers. Efficiently and effectively extract value and insights from streamed and stored video, and help deliver a smarter world with advanced WD Purple Pro smart video storage.
  • Western Digital's exclusive AllFrame AI technology
    All WD Purple Pro drives are equipped with AllFrame AI technology, which not only improves ATA streaming to help reduce frame loss and improve overall video playback, but supports up to 32 AI streams for Deep Learning analytics within the system.
  • Multiple cameras, multiple streams
    Modern recorders now support multiple video streams per camera. WD Purple Pro drives are optimized to support up to 64 HD single-stream cameras, and can also support the latest smart cameras that transmit multiple streams. With this flexibility, you can upgrade or scale your security or smart video solution in the future.
  • Advanced workload capability for advanced systems
    WD Purple Pro drives feature a workload rating up to 550TB/year to support the heavy video data capture and analysis found in advanced AI-enabled recorders, video analytics appliances, deep learning analytics servers and cloud-based storage. The combination of streaming optimizations and enhanced durability and reliability make WD Purple Pro smart video storage ideal for all analytics servers, whether processing video streamed directly from cameras or large-scale captured video data sets.
  • Designed for reliable operation in advanced high-performance smart video solutions
    With an MTBF of up to 2.5 million hours, WD Purple Pro drives are engineered for advanced smart video solutions that operate 24/7. With tarnish resistant components and full multi-bay support, WD Purple Pro drives deliver reliable operation in large scale surveillance systems even in harsh environments.
  • Field-proven high capacity
    Now on its 6th generation, field-proven HelioSeal technology delivers trusted high capacity WD Purple Pro hard for the massive storage needs of AI-driven smart video and deep learning analytics.
  • Proactive storage management with WDDA
    Western Digital Device Analytics (WDDA) provides a wealth of storage device parametric operational and diagnostic data compatible systems; algorithms interpret the data and direct the system to alert system administrators of specific recommended actions to address potential issues. WDDA is intended to empower OEMs, system integrators, and IT professionals to better monitor and proactively manage supported storage devices to maintain optimal operation.
WD Purple Pro WD101PURP - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Advanced Format technology, 24x7 continuous operation, Conventional magnetic recording (CMR), AllFrame AI, support up to 64 cameras, tarnish-resistant
101.6 mm x 147 mm x 26.1 mm
750 g
5-year warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
265 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
9 Watt (read/write) , 8 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
RoHS 2011/65/EU
Limited warranty - 5 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5
Type: Hard drive
Capacity: 10TB
Brand: WD
