WD Purple 2TB 5400 RPM Serial ATA 3.5" 256MB
Quicklinx: H2KJWS00 Mfr#: WD22PURZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
40 In Stock
£81.52 ex VAT
£97.82 inc VAT
WD Purple drives are engineered specifically for surveillance to help withstand the elevated heat fluctuations and equipment vibrations within NVR environments. An average desktop drive is built to run for only short intervals, not the harsh 24/7 always-on environment of a high-definition surveillance system. With WD Purple, you get reliable, surveillance-class storage that's tested for compatibility in a wide range of security systems. Exclusive AllFrame technology helps reduce frame loss and improve overall video playback.
  • Surveillance you can trust
    With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust.
  • Western Digital's exclusive AllFrame technology
    All WD Purple drives are equipped with AllFrame technology, which improves ATA streaming to help reduce frame loss and improve overall video playback, within a multitude of security video solutions.
  • Designed for today's and tomorrow's surveillance solutions
    WD Purple drives are engineered for mainstream surveillance DVRs and NVRs that operate 24/7. With tarnish-resistant components and support for more than eight bays, WD Purple drives deliver reliable operation even in harsh environments.
  • Wide compatibility, seamless integration
    WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of industry-leading enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you.
WD Purple WD22PURZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Advanced Format technology, Conventional magnetic recording (CMR), support up to 64 cameras, AllFrame
101.6 mm x 147 mm x 26.1 mm
450 g
3-year warranty
2 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
175 MBps
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
3.8 Watt (read/write) , 3.2 Watt (idle) , 0.3 Watt (standby) , 0.3 Watt (sleep)
RoHS 2011/65/EU
Shipping Width
12.7 cm
Shipping Depth
19.05 cm
Shipping Height
6.35 cm
Shipping Weight
860 g
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: WD
