With a 1.6GHz quad-core IntelĀ® PentiumĀ® N3710 processor, 4GB of DDR3L RAM, and built-in video transcoding, you get a multi-purpose media server with the power to stream in HD, capacity to store all your raw files and sharing capabilities to collaborate with ease. Optimized for the Plex media server, your HD videos are prepared for streaming whenever you need them, on any compatible device.
- WD My Cloud PR2100 WDBBCL0000NBK - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.86 cm x 21.61 cm x 14.78 cm
- 2.2 kg ()
- Localisation
- EMEA
- Processor
- 1 x Intel Pentium N3710 1.6 GHz (Quad-Core)
- Storage Controller
- RAID RAID 0, 1, JBOD
- Networking
- 1GbE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- System Requirements
- Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Microsoft Windows 7 / 8 / 10, Apple OS X 10.11 El Capitan
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 16 TB
- 10.86 cm
- 21.61 cm
- 14.78 cm
- 2.2 kg ()
- Localisation
- EMEA
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.56 GHz
- RAM
- 4 GB DDR3L
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, JBOD
- Data Link Protocol
- 1GbE
- DLNA Media Server, Apple Time Machine compatible, Dropbox support, built-in hardware transcoding
- Encryption Algorithm
- 256-bit AES
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 2 (total) / 2 (free) x internal
- 2 x Ethernet 1000Base-T , 2 x USB 3.0
- Cables Included
- 1 x network cable
- Directive 2002/95/EC, NRCAN
- Power Device
- External power adapter
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- Software Included
- WD Sync, WD SmartWare Pro, WD Access
- OS Required
- Limited warranty - 2 years
- 0 °C
- 35 °C
