WD My Cloud DL2100 0TB 2-Bay 3.5"
Quicklinx: B4G6WS00 Mfr#: WDBBAZ0000NBK-EESN
  • Atom
Built from the ground up with hardware, software and storage from WD, My Cloud Business Series DL2100 is a true all-in-one, high-performance NAS solution designed for small businesses. The fully integrated, easy to deploy system provides the reliability, security, and scalability needed to drive small business success.
  • Keep your business data in one safe, efficient place
    Centralize and protect critical business data from all the PC and Mac computers in your workplace on one, easy to manage NAS solution. And with secure remote and mobile access, you can get to it anytime, from anywhere to share files with employees, partners and customers.
  • Performance to boost your business
    Powered by a high-performance processor, My Cloud DL2100 delivers optimal multi-user and multi-application performance your business needs to maximize productivity. Ultra-fast read and high write speeds give your business the power to transfer large amounts of files simultaneously, enhancing workplace efficiency.
  • Built-in reliability your business demands
    My Cloud Business Series pre-configured NAS come populated with WD NAS hard drives. Ultra-reliable and purposely built for NAS systems, WD drives improve performance and thrive in 24 x 7 environments.
  • Robust data protection to safeguard critical business data
    Lost data means lost business, so My Cloud DL2100 offers comprehensive data protection options to secure your files from unexpected loss. Protect all the PC and Mac computers in your workplace using local, remote or cloud backup. Multiple RAID configurations and volume encryption add even more protection and security for all your files. And with dual NICs and dual power ports, My Cloud DL2100 keeps you connected to your data in case of network connection or power supply failure.
  • Capacity and performance you need today, scalable for the future
    My Cloud Business Series devices are designed to keep up with your future storage and performance needs. Easily hot swap in larger drives without turning off the device, keeping your business up and running. The built-in memory expansion slot allows you to increase RAM for improved system performance. For even more storage and speed, My Cloud DL2100 is equipped with dual Gigabit Ethernet ports that allow you to daisy-chain to another NAS device for increased network storage capacity.
  • Seamless business environment integration
    Integrate My Cloud Business Series NAS into your existing Active Directory for streamlined file sharing, easy data management and increased business efficiency.
  • Perfect fit for virtualization environments
    With integrated iSCSI support, My Cloud Business Series NAS easily provide storage for virtual machines, applications and servers on your network, giving you fast access to your business data.
  • Automatically copy your external USB with the touch of a button
    With the built-in, one-touch copy button conveniently located on the front of the system, you can automatically copy all the files you have stored on an external USB to the My Cloud DL2100, keeping all your business files in one safe, central location.
WD My Cloud DL2100 WDBBAZ0000NBK - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
10.86 cm x 21.61 cm x 14.78 cm
2.2 kg ()
EMEA
Intel Atom C2350 1.7 GHz (Dual-Core)
Storage Controller
RAID RAID RAID 0, 1, JBOD
1GbE
RAM
1 GB
Power Redundancy
Optional
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple OS X 10.8 Mountain Lion, Apple OS X 10.7.5 Lion, Windows 8.1, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
10.86 cm
21.61 cm
14.78 cm
2.2 kg ()
Enclosure Colour
Built-in Devices
Led panel
EMEA
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
1 GB (installed) / 5 GB (supported) - DDR3
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
1GbE
Network / Transport Protocol
NTP, iSCSI, Bonjour, DDNS
Remote Management Protocol
SNMP 2, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Internet Storage Name Service (iSNS), Web-based Distributed Authoring and Versioning (WebDAV)
VLAN support, IPv6 support, SSH support, iTunes server, Jumbo Frames support, FTP server, static IP mode, UPnP Media Server, IPv4 support, TwonkyMedia server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), DHCP client, e-mail notification, cloud backup
Encryption Algorithm
256-bit AES
IEEE 802.1Q, DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 2 (free) x hot-swap - 3.5"
2 x Ethernet 1000 - RJ-45 , 2 x USB 3.0
1 x network cable
Wake on LAN, UPS support, automatic fan speed control, firmware upgradable, scheduled power on/off, Full Volume Encryption, RAID Level Migration, Spin Down Idle Disk, tray-less design, one-touch copy button
RoHS, Directive 2002/95/EC
External power adapter
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Software Included
Photos, WD My Cloud, WD Quickview, WD SmartWare Pro (25-users licence)
35 °C
B4G6 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
