WD Red Plus drives are built for up to eight-bay NAS systems and pack the power to store your precious data in one powerhouse unit.
Compatible
Tested with a wide range of NAS systems for optimum performance and compatibility. -
Reliable
Designed to operate in the always-on environment of a NAS or RAID configuration. -
High capacity
The high capacity allows the flexibility to build the optimal NAS solution.
- WD Red Plus WD101EFAX - hard drive - 10 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 5400 rpm
- Native Command Queuing (NCQ), Advanced Format technology, NASware technology, 24x7 continuous operation, Error Recovery Control
- 101.6 mm x 147 mm x 26.1 mm
- 750 g
- 3-year warranty
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 750 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 215 MBps
- Spindle Speed
- 5400 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 8.4 Watt (read/write) , 4.6 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
- RoHS 2011/65/EU
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
