WD HDD Ext 8TB Elements Desktop USB3 Black
Quicklinx: F9HWWS00 Mfr#: WDBWLG0080HBK-EESN
Form Factor: [N/A]
Type: Hard drive
Interface Type: USB
Capacity: 8TB
Spin Speed (rpm): [N/A]
£214.30 ex VAT
£257.16 inc VAT
The compact design offers high capacity, making WD Elements desktop storage the ideal solution for easy, add-on storage of all your important photos, music, videos and files.
  • Improve PC performance
    When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements desktop storage and get your computer moving again.
  • USB 3.0 and USB 2.0 compatibility
    With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
WD Elements Desktop WDBWLG0080HBK - hard drive - 8 TB - USB 3.0
Hard drive - external (desktop)
8 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
NTFS formatted
Power Source
Included AC adapter
48 mm x 135 mm x 165.8 mm
EMEA
8 TB
USB 3.0
NTFS formatted
48 mm
135 mm
165.8 mm
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Apple MacOS X, Microsoft Windows 7 / 8.1 / 10
1 x USB 3.0 cable - external
EMEA
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
Form Factor: [N/A]
Type: Hard drive
Interface Type: USB
Capacity: 8TB
Brand: WD
