WD Green WDS240G3G0A 2.5" 240GB Serial ATA III SSD
Quicklinx: H2J4WS00 Mfr#: WDS240G3G0A
Form Factor: 2.5
Capacity: 240GB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 1 left in stock!
£20.83 ex VAT
£24.99 inc VAT
Express delivery Order within the next 20 hours for delivery on Tuesday
WD Green hard drives are designed for use in systems that require cool and quiet operation, as secondary drives in PCs, for external enclosures and other applications for which low noise and low heat are beneficial. These earth-friendly hard drives are ideal for use whenever energy efficiency is needed.
  • Leading the way to green hard drives
    WD led the industry in creating a category of hard drives that use less power and helps to reduce the world's energy demands one computer user at a time. With over 90 million WD Green drives sold customers using WD Green drives have saved the planet over 466 million kwh of power - nearly equaling the annual power production of a single coal power plant!
  • Conflict-free materials
    As a leader in hard drive manufacturing, WD proudly guarantees hard drives are built with 100% conflict free raw materials.
  • Halogen free
    In addition to being RoHS compliant, all WD Green drives are lead and halogen free, resulting in less pollutants getting into environment.
  • Reduced rare earths dependency
    WD Green hard drives are built using less rare earth minerals. Reduced power consumption Best-in-class power management technology delivers significant power savings and solid performance.
  • Cool and quiet
    WD GreenPower technology yields lower operating temperatures for increased reliability and low acoustics perfect for ultra-quiet PCs and external drives.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • IntelliSeek
    Calculates optimum seek speeds to lower power consumption, noise and vibration.
WD Green WDS240G3G0A - SSD - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
69.85 mm x 100.5 mm x 7 mm
36.2 g
3-year warranty
240 GB
2.5"
SATA 6Gb/s
69.85 mm
100.5 mm
7 mm
36.2 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
545 MBps
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
60 mW (active) , 1.7 Watt (max read) , 1.7 Watt (max write) , 26 mW (sleep) , 10 mW (DevSleep)
UL, TUV, VCCI, BSMI, FCC, KC, RCM, Morocco, UKCA
Limited warranty - 3 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
Form Factor: 2.5
Capacity: 240GB
Brand: WD
Stock Status: While stocks last
Stock Status: Clearance
