Your Data is Gold
Customise your business’s storage mix to fit your specific needs with a full portfolio of enterprise-class WD Gold HDDs in capacities of 1TB to 24TB1, with OptiNAND™ technology in 20TB, 22TB and 24TB. These highly reliable solutions for demanding storage environments provide up to 2.5M hours MTBF3, vibration protection technology, and a low power draw thanks to HelioSeal technology (for 12TB and above). Specifically designed for use in enterprise-class data centers and storage systems, WD Gold SATA HDDs deliver the world-class performance you expect from Western Digital hard drives.
More Flexibility, More Freedom
WD Gold lets you build out your storage your way with a full portfolio of SATA HDDs from 1TB to 24TB1, engineered for heavy application workloads and designed to handle workloads up to 550TB2 per year.
Enhanced Reliability
With up to 2.5M hours MTBF3, WD Gold hard drives deliver enhanced levels of dependability and durability.
Vibration Protection
WD Gold drives have sophisticated monitoring electronics that help correct linear and rotational vibrations in real time using enhanced vibration protection technology for improved performance in high-vibration environments.
Plays Well with Others
Specifically designed for use in enterprise-grade storage systems and data centers, WD Gold HDDs are broadly compatible with major enterprise operating systems.
Scale Your Business
WD Gold drives are available in capacities up to 24TB utilizing the OptiNAND technology's capacity-enabling feature.
Helps Protect Your Data
The innovative ArmorCache feature (22TB and 24TB only) provides enterprise power loss protection of your data in write-cache enabled (WCE) mode while increasing performance in write-cache disabled (WCD) mode.
- WD Gold WD221KRYZ - hard drive - Enterprise - 22 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 22 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 512 MB
- Spindle Speed
- 7200 rpm
- Drive Class
- Enterprise
- HelioSeal, advanced format 512e, OptiNAND technology
- 101.6 mm x 147 mm x 26.1 mm
- 670 g
- 5-year warranty
- Capacity
- 22 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 512 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 670 g
Performance
- Drive Class
- Enterprise
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 291 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 7.1 Watt (active) , 5.7 Watt (idle)
- OS Required
- Linux, Microsoft Windows Server, Microsoft Windows
- ROHS Directive 2015/863/EU, ROHS Directive 2011/65/EU
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine wave
- Sound Emission
- 20 dBA
