WD Gold 22TB 7200 RPM Serial ATA III 3.5" 512MB
Quicklinx: H2KKWS00 Mfr#: WD221KRYZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 22TB
Spin Speed (rpm): 7200rpm
£461.52 ex VAT
£553.82 inc VAT
Your Data is Gold
Customise your business’s storage mix to fit your specific needs with a full portfolio of enterprise-class WD Gold HDDs in capacities of 1TB to 24TB1, with OptiNAND™ technology in 20TB, 22TB and 24TB. These highly reliable solutions for demanding storage environments provide up to 2.5M hours MTBF3, vibration protection technology, and a low power draw thanks to HelioSeal technology (for 12TB and above). Specifically designed for use in enterprise-class data centers and storage systems, WD Gold SATA HDDs deliver the world-class performance you expect from Western Digital hard drives.
More Flexibility, More Freedom
WD Gold lets you build out your storage your way with a full portfolio of SATA HDDs from 1TB to 24TB1, engineered for heavy application workloads and designed to handle workloads up to 550TB2 per year.
Enhanced Reliability
With up to 2.5M hours MTBF3, WD Gold hard drives deliver enhanced levels of dependability and durability.
Vibration Protection
WD Gold drives have sophisticated monitoring electronics that help correct linear and rotational vibrations in real time using enhanced vibration protection technology for improved performance in high-vibration environments.
Plays Well with Others
Specifically designed for use in enterprise-grade storage systems and data centers, WD Gold HDDs are broadly compatible with major enterprise operating systems.
Scale Your Business
WD Gold drives are available in capacities up to 24TB utilizing the OptiNAND technology's capacity-enabling feature.
Helps Protect Your Data
The innovative ArmorCache feature (22TB and 24TB only) provides enterprise power loss protection of your data in write-cache enabled (WCE) mode while increasing performance in write-cache disabled (WCD) mode.
WD Gold WD221KRYZ - hard drive - Enterprise - 22 TB - SATA 6Gb/s
Hard drive - internal
22 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
7200 rpm
Drive Class
Enterprise
HelioSeal, advanced format 512e, OptiNAND technology
101.6 mm x 147 mm x 26.1 mm
670 g
5-year warranty
22 TB
3.5"
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
670 g
Performance
Drive Class
Enterprise
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
291 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.1 Watt (active) , 5.7 Watt (idle)
Linux, Microsoft Windows Server, Microsoft Windows
ROHS Directive 2015/863/EU, ROHS Directive 2011/65/EU
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine wave
Sound Emission
20 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 22TB
Brand: WD
