WD Gold 20TB 7200 RPM Serial ATA III 3.5" 512MB
Quicklinx: H2KLWS00 Mfr#: WD202KRYZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 20TB
Spin Speed (rpm): 7200rpm
£363.11 ex VAT
£435.73 inc VAT
Customize your business’s storage mix to fit your specific needs with a full portfolio of enterprise-class WD Gold HDDs in capacities of 1TB to 22TB(1), with OptiNAND technology in 20TB and 22TB. These highly reliable solutions for demanding storage environments provide up to 2.5M hours MTBF(3), vibration protection technology, and a low power draw thanks to HelioSeal technology (for 12TB and above). Specifically designed for use in enterprise-class data centers and storage systems, WD Gold SATA HDDs deliver the world-class performance you expect from Western Digital hard drives.
WD Gold WD202KRYZ - hard drive - Enterprise - 20 TB - SATA 6Gb/s
Hard drive - internal
20 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
7200 rpm
Drive Class
Enterprise
HelioSeal, advanced format 512e, OptiNAND technology
101.6 mm x 147 mm x 26.1 mm
690 g
5-year warranty
20 TB
3.5"
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Drive Class
Enterprise
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
269 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.9 Watt (active) , 5.8 Watt (idle)
Linux, Microsoft Windows Server, Microsoft Windows
RoHS 2011/65/EU, RoHS 2015/863/EU
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
50 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine wave
Sound Emission
20 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 20TB
Brand: WD
