WD Blue SA510 M.2 500GB Serial ATA III SSD
Quicklinx: H2HTWS00 Mfr#: WDS500G3B0B
Form Factor: M.2 2280
Capacity: 500GB, 500GB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 2 left in stock!
£114.87 ex VAT
£137.84 inc VAT
Breathe new life into your PC so you can push the boundaries of your work. Designed specifically for professionals, creatives, freelancers, social influencers, and other passionate content creators and editors, the WD Blue SA510 SATA SSD helps boost your PC's performance so you can be more productive. This fast, reliable SSD helps you boot up faster, cut lag times, and speed up edits and file transfers for a sustainable desktop upgrade - no expensive new PC purchase required.
  • Upgrade your creativity
    Featuring high read speeds, this fast SATA SSD delivers a performance boost that keeps up with your workloads so you can stay creative and be more productive.
  • Give your PC a makeover
    Why buy an expensive new desktop? With great capacity, high endurance, plus low power draw for more laptop life between charges and reduced vibrations compared to HDDs, the WD Blue SA510 SATA SSD is the perfect drive for a powerful PC upgrade.
  • Create with more control
    Stress less and keep your projects on point as the downloadable Western Digital SSD Dashboard helps you monitor your drive's health, temperature, available space, firmware version, and more.
WD Blue SA510 WDS500G3B0B - SSD - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Enclosure Colour
Blue
22 mm x 80 mm x 2.38 mm
4.8 g
5-year warranty
500 GB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
2.38 mm
4.8 g
Performance
SSD Endurance
200 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 510 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
82000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
M.2 2280
Power Consumption
50 mW (active) , 1800 mW (read) , 2000 mW (write) , 36 mW (sleep) , 12 mW (DevSleep)
Software Included
Acronis True Image, Dropbox Professional (free for 3 months)
UL, TUV, VCCI, BSMI, FCC, KC, Morocco
Enclosure Colour
Blue
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 gRMS @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 gRMS @ 7-800 Hz
Capacity: 500GB
Capacity: 500GB
Brand: WD
