WD Blue SA510 M.2 1TB Serial ATA III SSD
Quicklinx: H2HRWS00 Mfr#: WDS100T3B0B
Form Factor: M.2 2280
Capacity: 1TB, 1TB
Interface: Serial ATA-600
Type: Internal hard drive
47 In Stock
£52.60 ex VAT
£63.12 inc VAT
Upgrade Your Creativity
Featuring read speeds up to 560MB/s1 (500GB, 1TB and 2TB models), this fast SATA SSD delivers a performance boost that keeps up with your workloads so you can stay creative and be more productive.
Give Your PC a Makeover
Why buy an expensive new desktop? With capacities of up to 2TB2, high endurance,plus low power draw for more laptop life between charges and reduced vibrations compared to HDDs, the WD Blue SA510 SATA SSD is the perfect drive for a powerful PC upgrade.
Easily Share Files with Dropbox
Dropbox makes it easier than ever to store and collaborate. Share your content—from photos and videos to documents and presentations.
Create with More Control
Stress less and keep your projects on point as the downloadable Western Digital SSD Dashboard helps you monitor your drive’s health, temperature, available space, firmware version, and more.
Plug It into Your Current PC
The WD Blue SA510 SATA SSD comes in 2.5" and M.2 form factors for increased compatibility, fitting into many PC slots including those of many older machines.
Disclosures
1. 1GB = 1 billion bytes and 1TB = 1 trillion bytes. Actual user capacity may be less depending on operating environment.
2. Based on read speed. 1 MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
WD Blue SA510 WDS100T3B0B - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Enclosure Colour
Blue
22 mm x 80 mm x 2.38 mm
4.8 g
5-year warranty
1 TB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
2.38 mm
4.8 g
Performance
SSD Endurance
400 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 520 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
82000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
M.2 2280
Power Consumption
60 mW (active) , 1800 mW (read) , 2000 mW (write) , 36 mW (sleep) , 12 mW (DevSleep)
Software Included
Acronis True Image, Dropbox Professional (free for 3 months)
UL, TUV, VCCI, BSMI, FCC, KC, Morocco
Enclosure Colour
Blue
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 gRMS @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 gRMS @ 7-800 Hz
Capacity: 1TB
Capacity: 1TB
Brand: WD
