WD Blue SA510 2.5" 500GB Serial ATA III SSD
Quicklinx: H2HPWS00 Mfr#: WDS500G3B0A
Form Factor: 2.5
Capacity: 500GB, 500GB
Interface: Serial ATA-600
Type: Internal hard drive
43 In Stock
£39.60 ex VAT
£47.52 inc VAT
Elevate Your Creativity
Breathe new life into your PC so you can push the boundaries of your work. Designed specifically for professionals, creatives, freelancers, social influencers, and other passionate content creators and editors.
Upgrade Your Creativity
Featuring read speeds up to 560MB/s(2), this fast SATA SSD delivers a performance boost that keeps up with your workloads so you can stay creative and be more productive.
Give Your PC a Makeover
Why buy an expensive new desktop? High endurance, plus low power draw for more laptop life between charges and reduced vibrations compared to HDDs, the WD Blue SA510 SATA SSD is the perfect drive for a powerful PC upgrade.
Help Protect Your Content
Clone your computer’s entire hard drive to your WD Blue SA510 drive with the included Acronis True Image for Western Digital software. This easy, efficient software also helps provide AI-based protection against ransomware and defend you from many attacks.
Easily Share Files with Dropbox
Easily share files up to 100GB in only a few clicks, even if it’s too large to email. Impress your clients by adding custom branding, digital watermarks, passwords, or expiration dates to content you share via Dropbox® Professional.
Create with More Control
Stress less and keep your projects on point as the downloadable Western Digital SSD Dashboard helps you monitor your drive’s health, temperature, available space, firmware version, and more.
Plug It into Your Current PC
The WD Blue SA510 SATA SSD is compatible with a wide range of PC slots, including those of many older machines.
Disclosures
1. 1GB = 1 billion bytes and 1TB = 1 trillion bytes. Actual user capacity may be less depending on operating environment.
2. Based on read speed. 1 MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
  • Upgrade your creativity
    Featuring high read speeds, this fast SATA SSD delivers a performance boost that keeps up with your workloads so you can stay creative and be more productive.
  • Give your PC a makeover
    Why buy an expensive new desktop? With high capacity, high endurance, plus low power draw for more laptop life between charges and reduced vibrations compared to HDDs, the WD Blue SA510 SATA SSD is the perfect drive for a powerful PC upgrade.
WD Blue SA510 WDS500G3B0A - SSD - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Enclosure Colour
Blue
69.85 mm x 100.2 mm x 7 mm
34.6 g
5-year warranty
500 GB
2.5"
SATA 6Gb/s
69.85 mm
100.2 mm
7 mm
34.6 g
Performance
SSD Endurance
200 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 510 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
82000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
50 mW (active) , 1800 mW (read) , 2000 mW (write) , 36 mW (sleep) , 12 mW (DevSleep)
Software Included
Acronis True Image, Dropbox Professional (free for 3 months)
UL, TUV, VCCI, BSMI, FCC, KC, Morocco
Enclosure Colour
Blue
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 gRMS @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 gRMS @ 7-800 Hz
Form Factor: 2.5
Capacity: 500GB
Capacity: 500GB
Brand: WD
