WD Blue internal hard drives deliver reliability for office and web applications. They are ideal for use as primary drives in desktop PCs and for office applications.
NoTouch Ramp Load technology
The recording head never touches the disk media, ensuring significantly less wear to the recording head and media as well as better drive protection in transit. -
Low power consumption
State-of-the-art seeking algorithms and advanced power management features ensure low power consumption
- WD Blue WD80EAZZ - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5640 rpm
- 101.6 mm x 147 mm x 26.1 mm
- 750 g
- 2-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 750 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 5640 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Software Included
- Acronis True Image WD Edition
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Limited warranty - 2 years
