WD Blue 8TB 5640 RPM Serial ATA III 3.5" 128MB
Quicklinx: H2JHWS00 Mfr#: WD80EAZZ
WD Blue internal hard drives deliver reliability for office and web applications. They are ideal for use as primary drives in desktop PCs and for office applications.
  • NoTouch Ramp Load technology
    The recording head never touches the disk media, ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features ensure low power consumption
WD Blue WD80EAZZ - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5640 rpm
101.6 mm x 147 mm x 26.1 mm
750 g
8 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5640 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Software Included
Acronis True Image WD Edition
Microsoft Windows 7 / 8.1 / 10
