WD Blue 500GB Mobile Hard Disk Drive - 5400 RPM SATA 3Gb/s 2.5 Inch - WD5000LPVT
SOLID PERFORMANCE & RELIABILITY FOR NOTEBOOKS
Quicklinx: 84J4WS00 Mfr#: WD5000LPVT
WD Blue 2.5-inch SATA and PATA hard drives offer solid-performance, ultra-quiet operation and low-power use for portable digital devices of all kinds. Pick the drive that suits your needs with the confidence in knowing that all WD Scorpio Blue drives are built to the highest standards of quality and reliability.
  • Massive capacity
    Storage capacity for 2.5-inch form factor drives with standard 9.5 mm height has arrived at a realm once thought to be impossible - up to 1 TB - giving you all the capacity you need to keep your photos, music and files right there on your notebook.
  • Low power consumption
    State-of-the-art seeking algorithms optimize the way the drive seeks for data, which significantly improves power consumption.
  • Ultra cool and quiet
    In a notebook drive, silence is golden. WD's exclusive WhisperDrive technology delivers one of the quietest 2.5-inch hard drives on the market.
  • Designed for various applications
    WD Scorpio Blue has a portfolio of drives to satisfy all your portable computing needs. These drives are available in multiple z-heights including the 9.5 mm industry standard, 7 mm for use in thin notebooks and compatible with mainstream systems, and 12.5 mm primarily for external enclosures.
  • Reliable
    WD's SecurePark parks the recording heads off the disk surface during spin up, spin down, and when the drive is off. This ensures the recording head never touches the disk surface resulting in improved long term reliability due to less head wear, and improved nonoperational shock tolerance.
  • Rugged
    WD's ShockGuard technology protects the drive mechanics and platter surfaces from shocks.
WD Blue WD5000LPVT - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock Guard, WhisperDrive, SecurePark, Advanced Format technology
70 mm x 100 mm x 6.8 mm
90 g
500 GB
2.5"
SATA 3Gb/s
Buffer Size
8 MB
70 mm
100 mm
6.8 mm
90 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
147 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
RoHS
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
