WD Blue 3TB 5400 RPM Serial ATA 3.5" 256MB
Quicklinx: H2JKWS00 Mfr#: WD30EZAZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): 5400rpm
£80.30 ex VAT
£96.36 inc VAT
Western Digital WD Blue 3.5-inch PC hard drives deliver solid reliability for office and web applications, and they are perfect for extra storage for desktop PC computing.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
  • NoTouch ramp load technology
    Safely positions the recording head off the disk surface to protect your data.
  • Upgrading your drive is easy
    Seamlessly migrate your current system to your new Western Digital drive using Acronis True Image WD Edition cloning software, available as a free download on the WD Support site. This software enables you to copy all your data to a new drive so you don't have to reinstall your operating system to get all the benefits of a new drive.
WD Blue WD30EZAZ - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
101.6 mm x 147 mm x 26.1 mm
570 g
3 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
570 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Software Included
Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS High Sierra 10.13
Form Factor: 3.5
Type: Hard drive
Capacity: 3TB
Brand: WD
