Western Digital WD Blue 3.5-inch PC hard drives deliver solid reliability for office and web applications, and they are perfect for extra storage for desktop PC computing.
Low power consumption
State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption. -
NoTouch ramp load technology
Safely positions the recording head off the disk surface to protect your data. -
Upgrading your drive is easy
Seamlessly migrate your current system to your new Western Digital drive using Acronis True Image WD Edition cloning software, available as a free download on the WD Support site. This software enables you to copy all your data to a new drive so you don't have to reinstall your operating system to get all the benefits of a new drive.
- WD Blue WD30EZAZ - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 5400 rpm
- 101.6 mm x 147 mm x 26.1 mm
- 570 g
- 2-year warranty
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 570 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Software Included
- Acronis True Image WD Edition
- OS Required
- Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS High Sierra 10.13
- Limited warranty - 2 years
