Product
WD Blue 2TB Desktop Hard Disk Drive - 5400RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EZRZ
Clearance!
Clearance
Quicklinx: BKXQWS00 Mfr#: WD20EZRZ
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 5400rpm
£47.64 ex VAT
£57.16 inc VAT
Express delivery Order within the next 22 hours for delivery on Wednesday
High Capacity, Proven Reliability.
WD Blue hard drives deliver solid performance and reliability for desktops PCs, external enclosures and for certain industrial applications.
WD Blue WD20EZRZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
Data Lifeguard, IntelliSeek, NoTouch ramp load technology, Advanced Format technology
101.6 mm x 147 mm x 26.1 mm
600 g
2 years warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
600 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
4.1 Watt (read) , 4.1 Watt (write) , 3 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
RoHS 2011/65/EU
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
23 dB
Type: Hard drive
Capacity: 2TB
Brand: WD
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
