WD Blue 2TB 5400 RPM Serial ATA III 3.5" 256MB
Quicklinx: H2JLWS00 Mfr#: WD20EZAZ
Western Digital WD Blue 3.5-inch PC hard drives deliver solid reliability for office and web applications, and they are perfect for extra storage for desktop PC computing.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
  • NoTouch Ramp Load technology
    Safely positions the recording head off the disk surface to protect your data.
WD Blue WD20EZAZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
450 g
2 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.1 watt (read/write) , 2.3 watt (idle) , 0.4 watt (standby) , 0.4 watt (sleep)
Software Included
Acronis True Image WD Edition
RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
350 g @ 2 ms
