WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
                Low power consumptionState-of-the-art seeking algorithms and advanced power management features ensure low power consumption and long battery life.
                QuietIn a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield one of the quietest 2.5-inch hard drives on the market.
                The originalWD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning hard drives.
                NoTouch ramp load technologyThe recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
- WD Blue WD10JPVX - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- NoTouch ramp load technology, Advanced Format technology
- 69.85 mm x 100.2 mm x 9.5 mm
- 90 g
- 2-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- 69.85 mm
- 100.2 mm
- 9.5 mm
- 90 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 144 MBps
- Average Latency
- 5.5 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5" x 1/8H
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Shock Tolerance
- 400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
