Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
A modern classic
WD Blue storage is designed and manufactured with technology found in WD's original award-winning desktop and mobile hard drives. WD Blue sets the baseline for everyday storage by consistently delivering improved performance over previous generations while successfully maintaining WD's quality and reliability for over six generations. The difference is that colors never fade, generation after generation. -
The WD advantage
WD puts the products through extensive Functional Integrity Testing (F.I.T.) prior to any product launch. This testing ensures the products consistently meet the highest quality and reliability standards of the WD brand.
- WD Blue WD10EZEX - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- IntelliSeek, NoTouch ramp load technology
- 10.16 cm x 14.7 cm x 2.54 cm
- 440 g
- 2-year warranty
- Designed For
- My Cloud EX2
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 10.16 cm
- 14.7 cm
- 2.54 cm
- 440 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 150 MBps
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Shock Tolerance
- 65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
- Sound Emission
- 29 dBA
- Designed For
- WD My Cloud EX2
