WD Black 8TB 7200 RPM Serial ATA 3.5" 128MB
Quicklinx: H2JFWS00 Mfr#: WD8002FZWX
WD BLACK Gaming Hard Drives let you download the latest AAA titles while also keeping your ever-growing catalog of classics and favorites ready to play. Don't compromise on your game collection. Store more and game more with WD BLACK.
  • Gaming performance and capacity
    WD BLACK is purpose-built to enhance your PC gaming experience. The WD BLACK HDD is performance-optimized so you can spend more time gaming and less time loading. Combine a WD BLACK HDD with a WD BLACK SSD for a dual-drive configuration that maximizes your gaming experience while letting you keep more of your favorite games.
  • Drive your game
    The WD BLACK HDD is the perfect storage solution for your gaming rig, offering large cache sizes plus large capacities to store your favorite titles and their downloadable content (DLC). Paired with an SSD, the powerful drive delivers exceptional system performance and capacity.
  • Increased reliability
    The WD BLACK Gaming Hard Drive is equipped with StableTrac Technology. This secures the motor shaft inside of the hard drive to increase reliability and help reduce impact due to system-induced vibrations from other components such as additional gaming hardware. Stabilizing the platters inside the WD BLACK drive results in more accurate tracking in a particular sector during read and write operations, optimizing performance and reliability.
  • Commanding performance
    The WD BLACK drive delivers high-speed read rates and transfers of your games with impressive cache size. Western Digital's Dynamic Cache Technology improves caching algorithms in real time to allocate and optimize cache between reads and writes. Spend less time loading and more time winning.
  • Battle-tested dual processor
    When it comes to processing power, more is better for loading today's larger games. The WD BLACK Gaming Hard Drive features a dual-core processor that offers twice the processing capability as a single-core processor to maximize drive performance for getting into the game faster.
WD_BLACK WD8002FZWX - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
StableTrac, Advanced Format technology, Conventional magnetic recording (CMR), WD Dynamic Cache
101.6 mm x 147 mm x 26.1 mm
750 g
Worldwide
5-year warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
238 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
8.7 watt (read/write) , 7.9 watt (idle) , 0.29 watt (standby) , 0.29 watt (sleep)
Software Included
Acronis True Image WD Edition
RoHS 2011/65/EU
Worldwide
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
28 dBA
