As the industry evolves to develop purpose-built solutions for growing data storage requirements, IT managers continue to rely on lower capacity drives that are economical to acquire, yet deliver quick and reliable data access for traditional data center applications. Designed to handle heavy workloads, Ultrastar DC HC320 is a drive that helps address economic and access requirements of many traditional IT workloads. The Ultrastar DC HC320 is designed for traditional storage and server applications as well as distributed and scalable computing, including block and file storage architectures.
Technology innovation delivers efficiency and performance for traditional and legacy systems
Ultrastar DC HC310 is based on a 4-disk air platform design that uses conventional magnetic recording (CMR) technology in a 3.5-inch large form factor. Compared to the prior generation, Ultrastar 7K6000, the DC HC310 delivers a 12% performance boost and uses slightly larger-diameter media. It features a second-generation, dual-stage micro actuator to enhance head positioning accuracy for better drive performance. Write performance gains are also supported by Western Digital's media cache architecture, a disk-based caching technology that provides a large cache area on the disk, which also improves reliability and data integrity during unexpected power loss. Finally, the addition of flash-based non-volatile cache (NVC) on both SATA and SAS models helps improve write performance. The Ultrastar DC HC310 also includes a Rebuild Assist feature, which helps dramatically reduce RAID rebuild times and maintain system performance during the rebuild process. -
Data security with trusted quality, reliability
Compliance and privacy requirements drive the need for increased data security. Ultrastar DC HC310 helps protect data from unauthorized use by offering security and encryption options. SAS models offer hardware-based encryption options, including a Trusted Computing Group (TCG) Enterprise A, TCG with FIPS 140 - 2 certification, Level 2.
 - WD Ultrastar DC HC320 HUS728T8TALE6L4 - hard drive - 8 TB - SATA 6Gb/s
 - Hard drive - internal
- Capacity
 - 8 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 7200 rpm
 - Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), advanced format 512e, Dynamic fly height technology
 - 101.6 mm x 147 mm x 26.1 mm
 - 650 g
 - 5-year warranty
- Capacity
 - 8 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Buffer Size
 - 256 MB
- Bytes per Sector
 - 512
 - 101.6 mm
 - 147 mm
 - 26.1 mm
 - 650 g
Performance
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 205 MBps
- Seek Time
 - 8 ms (average) / 8.6 ms (max)
- Average Latency
 - 4.16 ms
- Spindle Speed
 - 7200 rpm
Reliability
- MTBF
 - 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
 - 1 per 10^15
- Load / Unload Cycles
 - 600,000
Expansion & Connectivity
 - 1 x SATA 6 Gb/s
- Compatible Bay
 - 3.5"
- Power Consumption
 - 8.8 Watt (active) , 7.4 Watt (idle)
 - RoHS 2011/65/EU
 - Limited warranty - 5 years
 - 5 °C
 - 60 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
 - 300 g @ 2 ms half-sine wave
- Vibration Tolerance (operating)
 - 0.67 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
 - 1.04 g @ 2-200 Hz
