Built for 24/7, always-on, high-definition security systems. With a supported workload rate of up to 180 TB/yr and support for up to 64 cameras, WD Purple drives are optimized for surveillance systems.
Seamless integration
With a wide range of industry-leading enclosures and chipsets supported, you're sure to find the configuration and compatibility that's right for your NVR. -
Less is more
Low power consumption is a must in a high-temperature, always-on surveillance environment. IntelliSeek technology helps reduce damaging ambient noise and vibrations. -
Designed for surveillance
The WD Purple drive is designed for both DVR and NVR security systems, and is compatible with many of the leading surveillance and security manufacturers.
- WD Purple Surveillance Hard Drive WD82PURZ - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 continuous operation, AllFrame AI
- 101.6 mm x 147 mm x 26.1 mm
- 715 g
- Localisation
- Worldwide
- 3-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 715 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 245 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 8.6 Watt (read) , 8.6 Watt (write) , 7.4 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
- RoHS, Directive 2011/65/EU
- Localisation
- Worldwide
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
