WD 8TB My Book USB3.0 Desktop External Hard Drive
Quicklinx: BYRYWS00 Mfr#: WDBFJK0080HBK-EESN
  • Up to 3x faster transfer rates
  • Universal connectivity
  • Local and cloud backup
  • System-level backup
  • Secure your files
  • WD quality inside and out
My Book desktop storage is optimized for the fastest possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to access and save files up to 3x faster than with USB 2.0.
With this drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
WD SmartWare pro automatic backup software lets you choose when and where you back up your files.
System-level backup
Acronis true image WD edition is an integrated software suite that helps secure all the information on your PC. With it you can back up your files on a system level, including your operating system, securely delete confidential data, restore backed up data quickly and restore your system should your computer crash. It's the perfect complement to the file level backup of WD SmartWare pro.
Secure your files
WD Security utility allows you to set password protection and hardware encryption for your drive to help keep your private stuff private.
  • Fast transfer rates
    My Book desktop storage is optimized for blazing-fast data transfer rates.
    With this drive you get compatibility with USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
  • Secure your files
    Your data is important to you, so the drive inside was built to demanding requirements for durability, shock tolerance and long-term reliability. Then, the drive was protected with a durable enclosure designed for beauty.
WD My Book WDBFJK0080HBK - hard drive - 8 TB - USB 3.0
Hard drive - external (desktop)
8 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Security lock slot (cable lock sold separately), password authentication, automatic backup, NTFS formatted
Power Source
Included AC adapter
Enclosure Colour
49 mm x 139.3 mm x 170.6 mm
1.01 kg
Middle East, Africa, Europe
8 TB
Hardware Encryption
USB 3.0
49 mm
139.3 mm
170.6 mm
1.01 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD SmartWare Pro
Apple MacOS X 10.6.5 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
5 °C
35 °C
