Specifically designed for use in enterprise servers, datacenter servers, and storage systems
Tested for 24x7x365 reliability at workloads up to 550TB per year
Performance-optimized for heavy application workloads
5-year limited warranty
Full range of nearline capacities
From entry-level servers to high end enterprise storage systems, WD Gold hard drives offer the capacities required for the most demanding datacenter environments. -
High workload capability
Delivering both performance and reliability to any datacenter environment, WD Gold hard drives are designed to handle workloads up to 550TB per year which is among the highest workload capability of any 3.5-inch hard drive. -
High level of reliability
With up to 2.5 million hours MTBF, WD Gold hard drives deliver one of the highest levels of reliability and durability for yearly operation (24x7x365) within the most demanding storage environments. -
Vibration Protection
Enhanced RAFF technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration in real time. The result is a significant performance improvement in high vibration environments. -
RAID-specific, time-limited error recovery (TLER)
Reduces drive fallout caused by the extended hard drive error-recovery processes common to desktop drives. -
Extended thermal burn-in test
Each drive is put through extended burn-in testing with thermal cycling to ensure reliable operation. -
Dynamic fly height technology
Each read-write head's fly height is adjusted in real time for optimum reliability. -
Dual actuator technology
A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy. -
Compatibility testing
All WD Gold hard drives are extensively tested across a variety of popular OEM storage systems, SATA controllers, and host bus adapters, to ensure ease of integration for a plug and play solution.
- WD Gold Datacenter Hard Drive WD8002FRYZ - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
- 101.6 mm x 147 mm x 26.1 mm
- 650 g
- 5-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 147 mm
- 26.1 mm
- 650 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 205 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 7.2 Watt (read) , 7 Watt (write) , 7.4 Watt (random read) , 5.1 Watt (idle)
- OS Required
- Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years , Technical support - phone consulting - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 300 g @ 1 ms half-sine wave
- Sound Emission
- 20 dBA
