Your basket is empty
WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM Datacenter Hard Drive
Quicklinx: C2KKWS00 Mfr#: WD8002FRYZ
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 8TB
Spin Speed (rpm): 7200rpm
48 in stock
£288.03 ex VAT
£345.63 inc VAT
  • Specifically designed for use in enterprise servers, datacenter servers, and storage systems
  • Tested for 24x7x365 reliability at workloads up to 550TB per year
  • Performance-optimized for heavy application workloads
  • 5-year limited warranty
WD Gold Datacenter Hard Drive WD8002FRYZ - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
101.6 mm x 147 mm x 26.1 mm
650 g
5 years warranty
8 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
205 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
7.2 Watt (read) , 7 Watt (write) , 7.4 Watt (random read) , 5.1 Watt (idle)
Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years , Technical support - phone consulting - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine wave
Sound Emission
20 dBA
WD 8TB Gold 3.5 Bundle deal on WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM Datacenter Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.35 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.47 | in stock
£304.08
saving £7.01
Cables
Including:
£290.77
saving £2.74
Type: Hard drive
Capacity: 8TB
Brand: WD
Price Range Ex VAT: 150 - 300
