WD 6TB Ultrastar DC HC310 7200 RPM SATA 3.5" Hard Drive
Quicklinx: DTNTWS00 Mfr#: 0B36039
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 6TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£162.36 ex VAT
£194.83 inc VAT
As the industry evolves to develop purpose-built solutions for growing data storage requirements, IT managers continue to rely on lower capacity drives that are economical to acquire, yet deliver quick and reliable data access for traditional data center applications. Ultrastar 7K6 is a low-capacity HDD, that helps address economic and access requirements of many traditional IT workloads. Low-capacity drives also help address architecture limitations. The Ultrastar 7K6 is designed for traditional storage and server applications as well as distributed and scalable computing, including block and file storage architectures, providing fast 7200 rpm performance and lower acquisition cost to help ease budget constraints.
  • Technology innovation delivers efficiency and performance for traditional and legacy systems
    Ultrastar 7K6 is based on a 4-disk air platform design that uses conventional magnetic recording (CMR) technology in a large form factor. Ultrastar 7K6 delivers a performance boost and uses slightly larger-diameter media. It features a dual-stage micro actuator to enhance head positioning accuracy for better drive performance. Write performance gains are also supported by Western Digital's media cache architecture, a disk-based caching technology that provides a large cache area on the disk, which also improves reliability and data integrity during unexpected power loss. Finally, the addition of flash-based non-volatile cache (NVC) helps improve write performance. The Ultrastar 7K6 also includes a Rebuild Assist feature, which helps dramatically reduce RAID rebuild times and maintain system performance during the rebuild process.
  • Data security with trusted quality, reliability
    Compliance and privacy requirements drive the need for increased data security. Ultrastar 7K6 helps protect data from unauthorized use by offering security and encryption options.
HGST Ultrastar 7K6 HUS726T6TALE6L4 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Secure Erase function, 24x7 continuous operation, advanced format 512e
101.6 mm x 147 mm x 26.1 mm
715 g
5 years warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
255 MBps
Seek Time
8 ms (average)
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.9 Watt (idle) , 7 Watt (typical)
VCCI, BSMI, CB, UL 60950-1, KCC, ICES, REACH, RCM, RoHS 2 (2011/65/EU)
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
0.67 g @ 5-500 Hz
Vibration Tolerance (non-operating)
1.04 g @ 2-200 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 6TB
Brand: WD
