As the industry evolves to develop purpose-built solutions for growing data storage requirements, IT managers continue to rely on lower capacity drives that are economical to acquire, yet deliver quick and reliable data access for traditional data center applications. Ultrastar 7K6 is a low-capacity HDD, that helps address economic and access requirements of many traditional IT workloads. Low-capacity drives also help address architecture limitations. The Ultrastar 7K6 is designed for traditional storage and server applications as well as distributed and scalable computing, including block and file storage architectures, providing fast 7200 rpm performance and lower acquisition cost to help ease budget constraints.
Technology innovation delivers efficiency and performance for traditional and legacy systems
Ultrastar 7K6 is based on a 4-disk air platform design that uses conventional magnetic recording (CMR) technology in a large form factor. Ultrastar 7K6 delivers a performance boost and uses slightly larger-diameter media. It features a dual-stage micro actuator to enhance head positioning accuracy for better drive performance. Write performance gains are also supported by Western Digital's media cache architecture, a disk-based caching technology that provides a large cache area on the disk, which also improves reliability and data integrity during unexpected power loss. Finally, the addition of flash-based non-volatile cache (NVC) helps improve write performance. The Ultrastar 7K6 also includes a Rebuild Assist feature, which helps dramatically reduce RAID rebuild times and maintain system performance during the rebuild process. -
Data security with trusted quality, reliability
Compliance and privacy requirements drive the need for increased data security. Ultrastar 7K6 helps protect data from unauthorized use by offering security and encryption options.
 - HGST Ultrastar 7K6 HUS726T6TALE6L4 - hard drive - 6 TB - SATA 6Gb/s
 - Hard drive - internal
- Capacity
 - 6 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 7200 rpm
 - Secure Erase function, 24x7 continuous operation, advanced format 512e
 - 101.6 mm x 147 mm x 26.1 mm
 - 715 g
 - 5 years warranty
- Capacity
 - 6 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Buffer Size
 - 256 MB
- Bytes per Sector
 - 512
 - 101.6 mm
 - 147 mm
 - 26.1 mm
 - 715 g
Performance
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 255 MBps
- Seek Time
 - 8 ms (average)
- Average Latency
 - 4.16 ms
- Spindle Speed
 - 7200 rpm
Reliability
- MTBF
 - 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
 - 1 per 10^15
- Load / Unload Cycles
 - 600,000
Expansion & Connectivity
 - 1 x SATA 6 Gb/s
- Compatible Bay
 - 3.5"
- Power Consumption
 - 5.9 Watt (idle) , 7 Watt (typical)
 - VCCI, BSMI, CB, UL 60950-1, KCC, ICES, REACH, RCM, RoHS 2 (2011/65/EU)
 - Limited warranty - 5 years
 - 5 °C
 - 60 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
 - 300 g @ 2 ms half-sine wave
- Vibration Tolerance (operating)
 - 0.67 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
 - 1.04 g @ 2-200 Hz
