WD 6TB Red NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD60EFRX
3 YEAR WARRANTY INCLUDED FOR ADDITIONAL PEACE OF MIND
Quicklinx: 9MMMWS00 Mfr#: WD60EFRX
WD Red™ Hard Drives for NAS: 3.5-inch, SATA 6 Gb/s, 64 MB cache
The right choice for Personal/Small Office/Home Office network attached storage.
WD NAS internal hard drives are the essential solution for NAS applications. These drives are cool and quiet, and offer optimum compatibility in 24x7 NAS systems with up to eight bays.
Storage for 1 to 8 bay NAS solutions - WD Red™ is designed specifically for NAS systems that have 1 to 8 drive bays in both 3.5-inch and 2.5-inch form factors. The drives are designed and extensively tested for compatibility in the unique 24x7 operating environment and for the demanding system requirements of home and small office NAS.
NASware grows to 3.0 - WD Red now supports small NAS systems from 1 to 8 bays thanks to NASware 3.0, which further improves drive compatibility and reliability. At 48 TB of potential capacity in an 8 bay system, WD Red expands your NAS experience.
Need help? We offer premium support - Every WD Red hard drive comes with our world-class professional support services including a premium dedicated 24/7 support line (available in English, other regional support hours vary) and a 3-year limited warranty.*
  • Support outside of normal business hours is available in English only. Go to http://support.wd.com for further details.
3D Active Balance Plus - Our enhanced dual-plane balance control technology significantly improves the overall drive performance and reliability. Hard drives that are not properly balanced may cause excessive vibration and noise in a multi-drive system, reduce the hard drive life span, and degrade the performance over time.
Longer warranty coverage - WD NAS hard drives are backed by a 3-year limited warranty for greater peace of mind.
The WD® advantage - WD puts our products through extensive Functional Integrity Testing (F.I.T.) prior to any product launch. On average, each new product goes through 600,000 hours of testing. WD also has a detailed Knowledge Base with more than 1,000 helpful articles. You can also call toll-free support 7 days per week in the U.S. and Canada. See the WD Support site for full details.
*Business critical RAID environments - Please consider WD NAS Hard Drives for all multi-bay consumer NAS environments. WD Red hard drives for up to 8 bay chassis and WD Red Pro hard drives for 8-16 bay chassis.
  • Optimal compatibility for NAS systems
  • Tested for 24x7 reliability
  • Specifically designed for use in NAS systems with up to 8 bays
  • 3-year limited warranty
  • Seamlessly integrates into your NAS system with up to 8 bays
  • Designed for the unique system requirements of NAS environments
  • Highly reliable, affordable solution for demanding 24x7 networking environments
  • Backed by a best-in-class 3-year limited warranty
  • WD NAS hard drives have been extensively tested for compatibility in 1-8 bay NAS systems in our FIT labs and AVL qualified with key NAS partners.
  • 3-year limited warranty EMEAi ["Europe"; "Middle East"; "Africa"; "India"]
Ideal For
  • Up to 8-bay NAS systems
  • Personal, Small and home office NAS
  • 24x7 NAS systems
  • Beyond desktop with NASware
    WD Red drives include WD's exclusive NASware technology that addresses many of the challenges a traditional desktop hard drive has in a NAS system. WD works directly with the partners to test compatibility and reduce thecustomer's guess work as to which drive is right for their NAS system. Designed to deliver a better customer experience in small NAS systems, this innovative firmware finely balances the most important attributes of performance, power, and reliability in multiple drive environments. The unique algorithms in NASware optimize power and performance without compromising on the attributes that NAS-system owner's value.
  • Important features for system integrators
    In addition to features that make WD Red drives perfect for populating or upgrading NAS systems, NASware brings features that system integrators need when building specialized NAS systems.
  • Save power and money
    NASware optimizes power use resulting in significant power savings and lower hard drive operating temperatures. This improves the overall reliability and performance of the drive and reduces the NAS cost of ownership.
  • Intelligent error recovery
    With built in intelligent error recovery controls, NASware also prevents hard drives from being dropped off the RAID due to extended error recovery. This provides more availability and less down time rebuilding the RAID.
  • Command completion
    To further improve reliability, NASware minimizes the data corruption or loss in the event of an unexpected power loss by completing the command in process before shutting down.
WD Red NAS Hard Drive WD60EFRX - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
750 g
3-year warranty
My Cloud EX2; EX4; PR2100; PR4100
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
175 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
5.3 Watt (read) , 5.3 Watt (write) , 3.4 Watt (idle) , 0.4 Watt (sleep)
Apple MacOS, Microsoft Windows 7 / Windows 8
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
25 dBA
WD My Cloud EX2 , WD My Cloud EX4 , WD My Cloud PR2100 , WD My Cloud PR4100
9MMM StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.30
9MMM StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
9MMM StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £66.18
