Watch your favorite entertainment on your schedule. Attach this drive to your recordable TV and save all your favorite programs, movies, and sporting events and watch them whenever you want. Created with an AV-grade drive inside, My Passport AV-TV delivers high-quality recording and crystal-clear playback of all your favorite programs making it the perfect drive for your recordable TV.
Built to thrive
Created with an AV-grade drive inside, My Passport AV-TV delivers high-quality recording and crystal-clear playback of all your favorite programs making it the perfect drive for your recordable TV. -
Maximum compatibility
My Passport AV-TV works with both USB 3.0 and USB 2.0 interfaces and is specifically designed for multimedia storage, making it compatible with most recordable TVs and other consumer electronic devices. -
USB 3.0 for simultaneous recording and playback
Super-fast USB 3.0 enables multiple HD streams for simultaneous recording and playback on new dual-tuner TVs. Record your favorite sitcom while watching the big match and never miss a moment of the action. -
Seamless installation
The small My Passport AV-TV fits neatly in your entertainment center. Use the included bracket mounting kit to easily attach it directly to the back of your TV for out-of-sight recording and playback. -
Engineered to last
My Passport AV-TV is designed to withstand the high demands of always-on, video streaming environments, giving you 24x7 reliability. -
USB powered
Powered only by the USB port on your recordable TV, My Passport AV-TV gives you all the TV recording storage you need without the clutter of cables.
- WD My Passport AV-TV WDBHDK5000ABK - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- Enclosure Colour
- Black
- 82.66 mm x 123.46 mm x 18.6 mm
- 148.1 g
- Localisation
- Middle East, Africa, Europe
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Capacity
- 500 GB
- Interface
- USB 3.0
- 82.66 mm
- 123.46 mm
- 18.6 mm
- 148.1 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Cables Included
- 1 x USB cable - 82 cm
- Mounting Kit
- Included
- RoHS
- Enclosure Colour
- Black
- Localisation
- Limited warranty - 2 years
- 0 °C
- 35 °C
- 0 - 60%
