WD 500GB Caviar Blue SATA-300 7200rpm 16MB
WD Caviar Blue
Customer rating: 5.0* (Write a review)
Quicklinx: 42DDWS00 Mfr#: WD5000AAKS
Please Note: This is a OEM Bare Drive
WD Caviar SE16 7200 RPM next-generation SATA hard drives feature 16 MB cache for lightning-fast performance, cool and quiet operation and up to 500 GB of storage for capacity-hungry applications.
  • The original
    WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives.
  • WD quality
    Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs.
  • More options
    These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
  • NoTouch Ramp Load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. SATA or PATA interface. While SATA has become the industry standard interface, WD continues to manufacture desktop drives with a PATA interface for unique or legacy systems.
  • Tested for compatibility
    WD perform tests on hundreds of systems and a multitude of platforms in the FIT Lab to give the customers confidence that the drives will work in their systemsUpgrading your drive is easy.
  • The WD advantage
    WD puts the products through extensive Functional Integrity Testing prior to any product launch. This testing ensures the products consistently meet the highest quality and reliability standards of the WD brand.
WD Blue WD5000KS - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Data Lifeguard, Shock Guard, SecureConnect, FlexPower, WhisperDrive, Soft Seek
10.2 cm x 14.7 cm x 2.54 cm
0.6 kg
Microsoft Certification
Works with Windows Vista
500 GB
3.5" x 1/3H
SATA 3Gb/s
Buffer Size
16 MB
10.2 cm
14.7 cm
2.54 cm
0.6 kg
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
93.5 MBps
Seek Time
8.9 ms (average) / 21 ms (max)
Track-to-Track Seek Time
2 ms
Average Latency
4.2 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
50,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
5 °C
55 °C
5 - 95%
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Vibration Tolerance
0.75 g @ 20-300 Hz (operating) / 4 g @ 20-500 Hz (non-operating)
Sound Emission
28 dBA
Customer reviews
Write a review for the WD 500GB Caviar Blue SATA-300 7200rpm 16MB here!
Quiet
Reviewed by Anonymous Review Posted 30/09/2007
Bought 2 of these to use as a RAID 1 mirrored pair with a Dabs Value 4 port SATA RAID PCI card (quicklinx 3Z2QWS). Very pleased as they are much quieter and noticeably faster than the 3 year old Western Digital and Maxtor IDE drives I had in my PC before. Remember you need adapters to power SATA drives if your motherboard has only the old IDE power connectors. Easy to set up and install in Windows XP as extra drive. Had problems cloning my old C drive onto the new mirrored pair with Western Digital Data Lifeguard (encountered errors during clone), Maxtor MaxBlast (clone appeared to work but WinXP hung on booting), Miray HDClone (did not recognise the SATA card). Recommend XXClone (freeware) for this - it was slow but worked.
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
WD Raptor
Reviewed by . Review Posted 01/12/2007
Because Raptors are 10,000RPM drives with 4ms seeks. Ideal for gaming, and faster than most desktop drives (New 500gb/1tb have better sustained transfers). You cant beat the Raptor for seek times with any other consumer drives. (Not including Enterprise storage, as we all know that Data is clever.)
  • Overall 5*
  • Ease of use 5*
Great once i figured them out
Reviewed by Anonymous Review Posted 11/03/2007
I bought two of these to create a 1TB JBOD RAID array. They did require a jumper in order to be detected by my motherboard but once I had figured that out (took a while!) they run really nice they're quiet compared to my old WD drive. Performance seems to be excellent also.
  • Overall 5*
  • Ease of use 3*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
