WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
Low power consumption
Amazing seeking algorithms and advanced power management features ensure low power consumption and long battery life. -
Quiet
In a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield one of the quietest 2.5-inch hard drives on the market. -
NoTouch ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
- WD Blue WD5000LPCX - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 5400 rpm
- NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
- 69.85 mm x 100.2 mm x 7 mm
- 90 g
- 2-year warranty
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 16 MB
- 69.85 mm
- 100.2 mm
- 7 mm
- 90 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 147 MBps
- Average Latency
- 5.5 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.4 watt (read) , 1.4 watt (write) , 0.55 watt (idle) , 0.16 watt (standby) , 0.16 watt (sleep)
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Shock Tolerance (operating)
- 400 g @ 2 ms
- Shock Tolerance (non-operating)
- 1000 g @ 2 ms
- Sound Emission
- 17 dBA
