WD 500GB Blue 2.5" 7mm SATA 6Gb/s 8MB Hard Drive
Quicklinx: F8L9WS00 Mfr#: WD5000LQVX
With better technology comes bigger storage needs. High-resolution photos, videos, music collections, games, and other important files require a lot of storage. Handling all that media is a snap with WD Blue hard drives.
  • The original
    WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives.
  • WD quality
    Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs.
  • More options
    These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
  • NoTouch Ramp Load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. SATA or PATA interface. While SATA has become the industry standard interface, WD continues to manufacture desktop drives with a PATA interface for unique or legacy systems.
  • Tested for compatibility
    WD perform tests on hundreds of systems and a multitude of platforms in the FIT Lab to give the customers confidence that the drives will work in their systemsUpgrading your drive is easy.
  • The WD advantage
    WD puts the products through extensive Functional Integrity Testing prior to any product launch. This testing ensures the products consistently meet the highest quality and reliability standards of the WD brand.
WD Blue WD5000LQVX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Enhanced Availability (EA) for 24x7 accessto data, Advanced Format technology
69.85 mm x 100.2 mm x 6.8 mm
95 g
500 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
6.8 mm
95 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
1.4 watt (read/write) , 0.5 watt (idle) , 0.2 watt (standby) , 0.2 watt (sleep)
RoHS 2011/65/EU
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
